Что делает «chmod + x filename» и как его использовать?
22
Я хочу написать аналог Ubuntu «командного файла» (сценарий оболочки). Но я не знаю, как использовать команду chmod +x filename , чтобы сделать ее так, чтобы скрипт мог быть запущен. Я также не знаю, где его использовать.
задан user265696 05.04.2014 в 21:26
22
Введите man chmod в окне терминала ( Ctrl + Alt + T ), и вы получите следующий результат:
СИНТАКСИС
chmod [OPTION]... MODE[,MODE]... FILE...
chmod [OPTION]... OCTAL-MODE FILE...
chmod [OPTION]... --reference=RFILE FILE...
ОПИСАНИЕ
This  manual page documents the GNU version of chmod.  chmod changes the
file mode bits of each given file according to mode, which can be either
a  symbolic representation of changes to make, or an octal number repre‐
senting the bit pattern for the new mode bits.
The format of a symbolic mode  is  [ugoa...][[+-=][perms...]...],  where
perms  is  either  zero or more letters from the set rwxXst, or a single
letter from the set ugo.  Multiple symbolic modes can  be  given,  sepa‐
rated by commas.
A  combination  of  the letters ugoa controls which users' access to the
file will be changed: the user who owns  it  (u),  other  users  in  the
file's  group (g), other users not in the file's group (o), or all users
(a).  If none of these are given, the effect is as if a were given,  but
bits that are set in the umask are not affected.
The  operator  +  causes  the selected file mode bits to be added to the
existing file mode bits of each file; - causes them to be removed; and =
causes them to be added and causes unmentioned bits to be removed except
that a directory's unmentioned set  user  and  group  ID  bits  are  not
affected.
The  letters  rwxXst  select file mode bits for the affected users: read
(r), write (w), execute (or search for directories) (x),  execute/search
only  if  the  file is a directory or already has execute permission for
some user (X), set user or group ID on execution (s),  restricted  dele‐
tion  flag  or sticky bit (t).  Instead of one or more of these letters,
you can specify exactly one of the letters ugo: the permissions  granted
to  the  user  who  owns  the file (u), the permissions granted to other
users who are members of the  file's  group  (g),  and  the  permissions
granted  to  users  that  are in neither of the two preceding categories
(o).
A numeric mode is from one to four octal digits (0-7), derived by adding
up  the  bits with values 4, 2, and 1.  Omitted digits are assumed to be
leading zeros.  The first digit selects the set  user  ID  (4)  and  set
group ID (2) and restricted deletion or sticky (1) attributes.  The sec‐
ond digit selects permissions for the user who owns the file: read  (4),
write  (2),  and  execute  (1);  the third selects permissions for other
users in the file's group, with the same  values;  and  the  fourth  for
other users not in the file's group, with the same values.
chmod  never changes the permissions of symbolic links; the chmod system
call cannot change their permissions.  This is not a problem  since  the
permissions  of  symbolic  links are never used.  However, for each sym‐
bolic link listed on the command line, chmod changes the permissions  of
the  pointed-to file.  In contrast, chmod ignores symbolic links encoun‐
tered during recursive directory traversals.
НАСТРОЙКИ И НАСТРОЙКИ SETGID
chmod clears the set-group-ID bit of a regular file if the file's  group
ID  does  not  match  the user's effective group ID or one of the user's
supplementary group IDs, unless the  user  has  appropriate  privileges.
Additional  restrictions may cause the set-user-ID and set-group-ID bits
of MODE or RFILE to be ignored.  This behavior depends on the policy and
functionality of the underlying chmod system call.  When in doubt, check
the underlying system behavior.
OPTIONS
Change the mode of each FILE to MODE.
   -c, --changes
          like verbose but report only when a change is made
   --no-preserve-root
          do not treat '/' specially (the default)
   --preserve-root
          fail to operate recursively on '/'
   -f, --silent, --quiet
          suppress most error messages
   -v, --verbose
          output a diagnostic for every file processed
   --reference=RFILE
          use RFILE's mode instead of MODE values
   -R, --recursive
          change files and directories recursively
   --help display this help and exit
   --version
          output version information and exit
   Each MODE is of the form '[ugoa]*([-+=]([rwxXst]*|[ugo]))+'.
Короче :
chmod +x в файле (ваш скрипт) означает только то, что вы сделаете его исполняемым. Щелкните правой кнопкой мыши на свой сценарий и выберите Свойства - > Разрешения - > Разрешить выполнение файла как программы , дает вам тот же результат, что и команда в терминале.
Если файл, который вы хотите изменить разрешения, находится в каталоге систем, вам может потребоваться root , например: (будьте осторожны при использовании команды sudo )
sudo chmod +x /usr/share/testfolder/aFile
Также неясно, что именно вы хотите здесь архивировать. Пожалуйста, отредактируйте свой вопрос и дайте более подробную информацию о реальной проблеме!
Вы также можете обратиться к этому вопросу за дополнительной информацией: chmod u + x 'versus' chmod + x
ответ дан v2r 05.04.2014 в 21:42
Во-первых, ваш скрипт должен объявить, какой интерпретатор использовать. Вы делаете это в первой строке файла. Если это скрипт оболочки, он должен быть #!/bin/sh или #!/bin/bash .
Итак, вот сценарий, который записывает ваше имя пользователя: echo-whoami.sh
#!/bin/sh echo $(whoami)
Чтобы сделать его исполняемым, используйте chmod +x echo-whoami.sh . Затем вы можете запустить его, используя ./echo-whoami.sh .
ответ дан Jo-Erlend Schinstad 08.07.2017 в 08:55
A командный файл и сценарий оболочки - это два термина, которые в то же время эффективны для Linux. Термин скрипт гораздо чаще используется .
Самый простой файл сценария оболочки просто содержит команды , поскольку вы вводите их в командной строке (то есть, интерпретаторе команд Bash). Теоретически вы можете даже заменить интерпретатора на любой язык, который вам нравится (и у вас есть переводчик). Чтобы быть более явным, предлагается начать первую строку с
#!/bin/sh (если вы неспособны к максимальной переносимости с устаревшими системами)
или
#!/bin/bash (если вам нужны дополнительные функции, вам, вероятно, сегодня не важно)
После этой строки введите свои команды, по одному на каждую строку. Есть много дополнительных конструкций, выходящих за рамки этих вопросов, см. man bash или Ссылка (для начинающих) или Ссылка (для более сложных вопросов).
Для фактического запуска вашего сценария есть два требования: во-первых, для процесса интерпретатора требуется прочитать файл , а во-вторых, проверяет, отмечен ли он как исполняемый . По соображениям удобства также полезно записывать сценарий (так что вы можете вносить изменения или исправления, если это необходимо).
Предполагая, что вы хотите, чтобы члены команды и другие пользователи могли запускать (и видеть) ваш скрипт, но вы не хотите, чтобы они манипулировали им, комбинация
  • выполнить права для всех ( a+x или +x , так как a по умолчанию),
  • читать права для всех ( a+r или +r , так как a снова по умолчанию),
  • написать разрешения только для вас ( u=w )
обычно являются разумными значениями ваших прав доступа к файлам. Вы можете ввести отдельные действия, объединенные запятыми.
В то время как этот «язык действия» очень увлекателен (обратите внимание на разницу в + и = , которые приводят к различным результатам в зависимости от настройки разрешения до их изменения), они утомительны для ввода.
Поскольку все действия создают битовые маски, которые применяются внутренне, вы можете также ввести битмаски (см. man chmod для деталей).
Для shellscript chmod 755 myscript.sh имеет наибольший смысл не менее 95% всех случаев.
ответ дан Nils Magnus 23.08.2017 в 17:34
