Почему мой раздел NTFS монтируется как только для чтения?
До недавнего времени мой Windows-раздел (C :) и мой раздел данных (E :) устанавливались как чтение / запись. Теперь оба кажутся только монтируемыми только для чтения.
GParted Resize (ошибка)
ntfsresize v2.0.0 (libntfs 10:0:0)
Device name : /dev/sda4
NTFS volume version: 3.1
Cluster size : 4096 bytes
Current volume size: 86207623680 bytes (86208 MB)
Current device size: 86207627264 bytes (86208 MB)
New volume size : 78662066688 bytes (78663 MB)
Checking filesystem consistency ...
Accounting clusters ...
Space in use : 62126 MB (72.1%)
Collecting resizing constraints ...
Needed relocations : 1606868 (6582 MB)
Schedule chkdsk for NTFS consistency check at Windows boot time ...
Resetting $LogFile ... (this might take a while)
Relocating needed data ...
ERROR: Extended record needed (1032 > 1024), not yet supported!
Please try to free less space.
chkdsk Выход:
Checking file system on E:
The type of the file system is NTFS.
Volume label is Data.
A disk check has been scheduled.
Windows will now check the disk.
  99482 file records processed.
  495 large file records processed.
  0 bad file records processed.
  0 EA records processed.
  0 reparse records processed.
  104412 index entries processed.
  0 unindexed files processed.
  99482 security descriptors processed.
  2466 data files processed.
CHKDSK is verifying Usn Journal...
  4479208 USN bytes processed.
Usn Journal verification completed.
Windows has checked the file system and found no problems.
84187132 KB total disk space.
  60479688 KB in 69969 files.
     15520 KB in 2467 indexes.
         0 KB in bad sectors.
    174336 KB in use by the system.
     65536 KB occupied by the log file.
  23517588 KB available on disk.
      4096 bytes in each allocation unit.
  21046783 total allocation units on disk.
   5879397 allocation units available on disk.
Internal Info:
9a 84 01 00 00 1b 01 00 fc 1a 01 00 00 00 00 00  ................
01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
42 00 00 00 52 73 5c 77 b0 e7 1d 00 b0 df 1d 00  B...Rs\w........
Fstab
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
proc            /proc           proc    nodev,noexec,nosuid 0       0
# / was on /dev/sda5 during installation
UUID=8213cc89-2438-41b9-899f-13b4c5b299af /               ext4    errors=remount-ro 0       1
# swap was on /dev/sda6 during installation
UUID=45873767-d9ae-4f0c-baab-ffc2726ac24e none            swap    sw              0       0
Проверьте диск в GParted, GSmartControl и ntfsfix , все успешно завершены, без изменений.
Перегородки
dev / sda1 NTFS WinRE
dev / sda2 NTFS Windows C:
dev / sda3 Расширенный
dev / sda4 NTFS Данные E:
dev / sda5 EXT4 Ubuntu
dev / sda6 linux-swap
Я ищу объяснение:
Internal Info:
и
задан Lewis Goddard 21.10.2011 в 15:36
21
В системе могут отсутствовать файлы для записи на разделы NTFS.
Попробуйте это в терминале: %код% и установите как ntfs-3g, так и все его зависимости.
Затем перезагрузите систему и попытайтесь открыть диск NTFS для доступа на запись. Теперь вы можете записать на диск NTFS.
ответ дан Thomas Ward 21.10.2011 в 16:34
Выполнение полное завершение работы Windows позволит полностью монтировать диски с помощью Ubuntu. Это можно сделать, удерживая клавишу SHIFT при нажатии кнопки «Выключить» в меню «Питание».
ответ дан schulwitz 02.06.2017 в 23:33
