E: Подпроцесс / usr / bin / dpkg возвращает код ошибки (1) -ERROR
Некоторое время назад я попытался установить пакет, который был успешным. Но после этого, если я попытаюсь установить любой новый пакет, я получаю сообщение об ошибке.
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
 cpp-4.8-arm-linux-gnueabihf : Depends: gcc-4.8-arm-linux-gnueabihf-base (= 4.8.4-2ubuntu1~14.04.1cross0.11.2) but 4.8.5-4ubuntu1cross2 is to be installed
 lib64gcc-4.7-dev:i386 : Depends: gcc-4.7-base:i386 (= 4.7.4-3ubuntu12) but it is not going to be installed
                         Depends: lib64gcc1:i386 (>= 1:4.7.4-3ubuntu12) but it is not going to be installed
                         Depends: libx32gcc1:i386 (>= 1:4.7.4-3ubuntu12) but it is not going to be installed
                         Depends: lib64gomp1:i386 (>= 4.7.4-3ubuntu12) but it is not going to be installed
                         Depends: libx32gomp1:i386 (>= 4.7.4-3ubuntu12) but it is not going to be installed
                         Depends: lib64itm1:i386 (>= 4.7.4-3ubuntu12) but it is not going to be installed
                         Depends: libx32itm1:i386 (>= 4.7.4-3ubuntu12) but it is not going to be installed
                         Depends: lib64quadmath0:i386 (>= 4.7.4-3ubuntu12) but it is not going to be installed
                         Depends: libx32quadmath0:i386 (>= 4.7.4-3ubuntu12) but it is not going to be installed
                         Recommends: libc6-dev:i386 (>= 2.13-0ubuntu6) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
После чего, если я запустил sudo apt-get -f install , я получаю следующую ошибку:
Correcting dependencies... Done
The following additional packages will be installed:
  cpp-4.8-arm-linux-gnueabihf gcc-4.8-arm-linux-gnueabihf
Suggested packages:
  gcc-4.8-locales gcc-4.8-multilib-arm-linux-gnueabihf gcc-4.8-doc libgcc1-dbg-armhf-cross libgomp1-dbg-armhf-cross libitm1-dbg-armhf-cross
  libatomic1-dbg-armhf-cross libasan0-dbg-armhf-cross libtsan0-dbg-armhf-cross libquadmath0-dbg-armhf-cross
The following packages will be upgraded:
2 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
633 not fully installed or removed.
Need to get 0 B/10.2 MB of archives.
After this operation, 967 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Setting up libegl1-mesa:amd64 (11.2.0-1ubuntu2.2) ...
update-alternatives: unknown argument '--force'
Usage: update-alternatives --install
       update-alternatives --remove
       update-alternatives --help
 is the link pointing to the provided path (ie. /usr/bin/foo).
 is the name in /usr/lib/opkg/alternatives/alternatives (ie. foo)
 is the name referred to (ie. /usr/bin/foo-extra-spiffy)
 is an integer; options with higher numbers are chosen.
dpkg: error processing package libegl1-mesa:amd64 (--configure):
 subprocess installed post-installation script returned error exit status 2
dpkg: dependency problems prevent configuration of libwayland-egl1-mesa:amd64:
 libwayland-egl1-mesa:amd64 depends on libegl1-mesa (= 11.2.0-1ubuntu2.2); however:
  Package libegl1-mesa:amd64 is not configured yet.
dpkg: error processing package libwayland-egl1-mesa:amd64 (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of libgtk-3-0:amd64:
 libgtk-3-0:amd64 depends on libwayland-egl1-mesa (>= 10.0.2) | libwayland-egl1; however:
  Package libwayland-egl1-mesa:amd64 is not configured yet.
  Package libwayland-egl1 is not installed.
  Package libwayland-egl1-mesa:amd64 which provides libwayland-egl1 is not configured yet.
dpkg: error processing package libgtk-3-0:amd64 (--configure):
dpkg: dependency problems prevent configuration of libgcr-ui-3-1:amd64:
 libgcr-ui-3-1:amd64 depends on libgtk-3-0 (>= 3.12.0); however:
  Package libgtk-3-0:amd64 is not configured yet.
dpkg: error processing No apport report written because the error message indicates its a followup error from a previous failure.
        No apport report written because MaxReports is reached already
        package libgcr-ui-3-1:amd64 (--configure):
dpkg: dependency problems prevent configuration of gcr:
 gcr depends on libgcr-ui-3-1 (>= 3.8.0); however:
  Package libgcr-ui-3-1:amd64 is not configured yet.
 gcr depends on libgtk-3-0 (>= 3.0.0); however:
dpkg: error processing package gcr (--configure):
dpkg: dependency problems prevent configuration of pinentry-gnome3:
 pinentry-gnome3 depends on libgtk-3-0 (>= 3.0.0); however:
 pinentry-gnome3 depends on gcr; however:
  Package gcr is not configured yet.
dpkg: error processing package pinentry-gnome3 (--configure):
dpkg: dependency problems prevent configuration of gnupg-agent:
 gnupg-agent depends on pinentry-curses | pinentry; however:
  Package pinentry-curses is not installed.
  Package pinentry is not installed.
  Package pinentry-gnome3 which provides pinentry is not configured yet.
dpkg: error processing package gnupg-agent (--configure):
dpkg: dependency problems prevent configuration of gnupg2:
 gnupg2 depends on gnupg-agent (= 2.1.11-6ubuntu2); however:
  Package gnupg-agent is not configured yet.
dpkg: error processing package gnupg2 (--configure):
Processing triggers for libc-bin (2.23-0ubuntu3) ...
 libegl1-mesa:amd64
 libgtk-3-0:amd64
 libgcr-ui-3-1:amd64
 gcr
 pinentry-gnome3
 gnupg-agent
 gnupg2
В любом случае, если try sudo apt-get update Я не вижу никакой ошибки.
Я попытался выполнить даже «dist upgrade» после ошибки:
sudo apt-get dist-upgrade -y
    You might want to run 'apt-get -f install' to correct these.
    cpp-4.8-arm-linux-gnueabihf : Depends: gcc-4.8-arm-linux-gnueabihf-base  (=.8.4-2ubuntu1~14.04.1cross0.11.2) but 4.8.5-4ubuntu1cross2 is installed
    E: Unmet dependencies. Try using -f.
Кто-то, пожалуйста, помогите мне в решении этой проблемы, поскольку это вызывает у меня проблему.
Также я прочитал другие сообщения, но никто не помог мне в исправлении моей проблемы.
задан subha ps 30.03.2017 в 08:31
0 ответов
