journalctl -xb фрагмент (что я считаю неправильным, оно было по крайней мере красным):
-- Unit systemd-fsckd.service has begun starting up.
juli 09 15:40:16 kim-SSD-Sationary systemd-fsck[414]: /dev/sdb1 contains a file system with errors, check forced.
juli 09 15:40:16 kim-SSD-Sationary systemd-fsck[414]: /dev/sdb1: Inodes that were part of a corrupted orphan linked list found.
juli 09 15:40:16 kim-SSD-Sationary systemd-fsck[414]: /dev/sdb1: UNEXPECTED INCONSISTENCY; RUN fsck MANUALLY.
juli 09 15:40:16 kim-SSD-Sationary systemd-fsck[414]: (i.e., without -a or -p options)
juli 09 15:40:16 kim-SSD-Sationary systemd-fsck[414]: fsck failed with error code 4.
juli 09 15:40:16 kim-SSD-Sationary systemd-fsck[414]: Running request emergency.target/start/replace
juli 09 15:40:16 kim-SSD-Sationary systemd[1]: systemd-fsck-root.service: main process exited, code=exited, status=1/FAILURE
juli 09 15:40:16 kim-SSD-Sationary systemd[1]: Failed to start File System Check on Root Device.
-- Subject: Unit systemd-fsck-root.service has failed
-- Defined-By: systemd
-- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- Unit systemd-fsck-root.service has failed.
-- The result is failed.
juli 09 15:40:16 kim-SSD-Sationary systemd[1]: Unit systemd-fsck-root.service entered failed state.
juli 09 15:40:16 kim-SSD-Sationary systemd[1]: systemd-fsck-root.service failed.
juli 09 15:40:16 kim-SSD-Sationary systemd[1]: Starting Remount Root and Kernel File Systems...
-- Subject: Unit systemd-remount-fs.service has begun start-up
Игнорирование других ошибок, таких как: Неисправность ACPI PCC, nvidia не является прогностическим и т. д.
EDIT: Я могу получить доступ к своему компьютеру, нажав Ctrl + D , но это раздражает.
