Проблема неудовлетворенных зависимостей 12.04 - libcurl4-openssl-dev зависит от librtmp-dev
У меня возникают проблемы с неудовлетворенными зависимостями от Ubuntu 12.04:
Вот что я получил после запуска sudo apt-get -f install , который предложил запустить apt-get autoremove
Вывод идентичен, если я запускаю sudo apt-get install librtmp-dev
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
  libmagick++4 libgtkspell0 libgsl0ldbl
Use 'apt-get autoremove' to remove them.
The following extra packages will be installed:
  librtmp-dev
The following NEW packages will be installed:
  librtmp-dev
0 upgraded, 1 newly installed, 0 to remove and 82 not upgraded.
1 not fully installed or removed.
Need to get 0 B/67.1 kB of archives.
After this operation, 201 kB of additional disk space will be used.
Do you want to continue [Y/n]? y
(Reading database ... 322166 files and directories currently installed.)
Unpacking librtmp-dev (from .../librtmp-dev_2.4~20110711.gitc28f1bab-1_i386.deb) ...
dpkg: error processing /var/cache/apt/archives/librtmp-dev_2.4~20110711.gitc28f1bab-1_i386.deb (--unpack):
trying to overwrite '/usr/include/librtmp/amf.h', which is also in package rtmpdump 2.5-0ubuntu2~precise
No apport report written because MaxReports is reached already
                                                          dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
И вот результат работы sudo apt-get autoremove
You might want to run 'apt-get -f install' to correct these.
  libcurl4-openssl-dev : Depends: librtmp-dev but it is not installed
E: Unmet dependencies. Try using -f.
Это результат после sudo dpkg --configure -a
dpkg: dependency problems prevent configuration of libcurl4-openssl-dev:
 libcurl4-openssl-dev depends on librtmp-dev; however:
  Package librtmp-dev is not installed.
dpkg: error processing libcurl4-openssl-dev (--configure):
 dependency problems - leaving unconfigured
Вывод sudo apt-get -u dist-upgrade
Список источников репозитория: cat /etc/apt/sources.list
# deb cdrom:[Ubuntu 12.04 LTS _Precise Pangolin_ - Release i386 (20120423)]/ precise main restricted
deb-src http://archive.ubuntu.com/ubuntu precise main restricted #Added by software-properties
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
deb http://bg.archive.ubuntu.com/ubuntu/ precise main restricted
deb-src http://bg.archive.ubuntu.com/ubuntu/ precise restricted main multiverse universe #Added by software-properties
## Major bug fix updates produced after the final release of the
## distribution.
deb http://bg.archive.ubuntu.com/ubuntu/ precise-updates main restricted
deb-src http://bg.archive.ubuntu.com/ubuntu/ precise-updates restricted main multiverse universe #Added by software-properties
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team. Also, please note that software in universe WILL NOT receive any
## review or updates from the Ubuntu security team.
deb http://bg.archive.ubuntu.com/ubuntu/ precise universe
deb http://bg.archive.ubuntu.com/ubuntu/ precise-updates universe
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## multiverse WILL NOT receive any review or updates from the Ubuntu
## security team.
deb http://bg.archive.ubuntu.com/ubuntu/ precise multiverse
deb http://bg.archive.ubuntu.com/ubuntu/ precise-updates multiverse
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
deb http://bg.archive.ubuntu.com/ubuntu/ precise-backports main restricted universe  multiverse
deb-src http://bg.archive.ubuntu.com/ubuntu/ precise-backports main restricted universe multiverse #Added by software-properties
deb http://security.ubuntu.com/ubuntu precise-security main restricted
deb-src http://security.ubuntu.com/ubuntu precise-security restricted main multiverse universe #Added by software-properties
deb http://security.ubuntu.com/ubuntu precise-security universe
deb http://security.ubuntu.com/ubuntu precise-security multiverse
## Uncomment the following two lines to add software from Canonical's
## 'partner' repository.
## This software is not part of Ubuntu, but is offered by Canonical and the
## respective vendors as a service to Ubuntu users.
deb http://archive.canonical.com/ubuntu precise partner
deb-src http://archive.canonical.com/ubuntu precise partner
## This software is not part of Ubuntu, but is offered by third-party
## developers who want to ship their latest software.
deb http://extras.ubuntu.com/ubuntu precise main
deb-src http://extras.ubuntu.com/ubuntu precise main
deb http://mirrors.dotsrc.org/getdeb/ubuntu precise-getdeb apps
deb-src http://mirrors.dotsrc.org/getdeb/ubuntu precise-getdeb apps
deb http://ppa.launchpad.net/musicbrainz-developers/stable/ubuntu precise main
deb-src http://ppa.launchpad.net/musicbrainz-developers/stable/ubuntu precise main
deb http://ppa.launchpad.net/nae-team/ppa/ubuntu precise main
deb-src http://ppa.launchpad.net/nae-team/ppa/ubuntu precise main
deb http://downloads.sourceforge.net/project/sonar-pkg/deb binary/
# deb-src http://downloads.sourceforge.net/project/sonar-pkg/deb binary/
apt-get clean и apt-get autoclean не делают ничего, чтобы исправить это.
И вот отчет о сбое:
Помогите, пожалуйста !!!
задан venta7 09.08.2014 в 18:17
Проблема заключается в том, что librtmp-dev trying to overwrite '/usr/include/librtmp/amf.h', which is also in package rtmpdump 2.5-0ubuntu2~precise . Скорее всего, PPA или какое-то другое репо предоставляют этот пакет, поскольку версия в основных репозиториях 2.4~20110711.gitc28f1bab-1 .
Решение состоит в том, чтобы удалить rtmpdump , выполнив sudo dpkg --remove rtmpdump , а затем запустить sudo apt-get install librtmp-dev , чтобы apt установил правильный пакет и настроил все необходимые пакеты.
ответ дан saiarcot895 09.08.2014 в 18:42
