проблемы с зависимостью предотвращают конфигурацию linux-headers-virtual
Я запускаю Ubuntu 12.04.2 LTS на виртуальной коробке и столкнулся с небольшой проблемой. Всякий раз, когда я пытаюсь выполнить обновление, я получаю:
apt-get upgrade
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these.
 linux-headers-virtual : Depends: linux-headers-3.2.0-44-virtual but it is not installed
 linux-virtual : Depends: linux-image-virtual (= 3.2.0.44.53) but 3.2.0.45.54 is installed
E: Unmet dependencies. Try using -f.
Если, однако, я пытаюсь установить -f (как было предложено), я получаю:
apt-get -f install
Correcting dependencies... Done
The following extra packages will be installed:
  linux-headers-virtual linux-virtual
The following packages will be upgraded:
2 upgraded, 0 newly installed, 0 to remove and 38 not upgraded.
2 not fully installed or removed.
Need to get 0 B/4,234 B of archives.
After this operation, 0 B of additional disk space will be used.
Do you want to continue [Y/n]? y
dpkg: dependency problems prevent configuration of linux-headers-virtual:
 linux-headers-virtual depends on linux-headers-3.2.0-44-virtual; however:
  Package linux-headers-3.2.0-44-virtual is not installed.
dpkg: error processing linux-headers-virtual (--configure):
 dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
dpkg: dependency problems prevent configuration of linux-virtual:
 linux-virtual depends on linux-image-virtual (= 3.2.0.44.53); however:
  Version of linux-image-virtual on system is 3.2.0.45.54.
 linux-virtual depends on linux-headers-virtual (= 3.2.0.44.53); however:
  Package linux-headers-virtual is not configured yet.
dpkg: error processing linux-virtual (--configure):
 linux-virtual
Любые идеи / предложения по устранению этой проблемы? Спасибо заранее.
PS: Я пробовал с apt-get autoremove и autoclean без везения.
Следуя предложению Митча, я попробовал dpkg --configure --pending, не повезло. Те же ошибки. Я также пробовал предлагать две другие команды, но их вывод не добавляет никакой другой информации к тому, что уже предусмотрено:
sudo dpkg --configure --pending
 linux-virtual
Как запросил lgarzo, вот некоторая информация:
uname -r
3.2.0-45-virtual
dpkg --list linux-[hi]* | cat
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name                            Version                      Description
un  linux-headers                   <none>                       (no description available)
un  linux-headers-3                 <none>                       (no description available)
un  linux-headers-3.0               <none>                       (no description available)
un  linux-headers-3.2.0-36          <none>                       (no description available)
un  linux-headers-3.2.0-36-virtual  <none>                       (no description available)
un  linux-headers-3.2.0-37          <none>                       (no description available)
un  linux-headers-3.2.0-37-virtual  <none>                       (no description available)
un  linux-headers-3.2.0-38          <none>                       (no description available)
un  linux-headers-3.2.0-38-virtual  <none>                       (no description available)
un  linux-headers-3.2.0-39          <none>                       (no description available)
un  linux-headers-3.2.0-39-virtual  <none>                       (no description available)
un  linux-headers-3.2.0-40          <none>                       (no description available)
un  linux-headers-3.2.0-40-virtual  <none>                       (no description available)
un  linux-headers-3.2.0-41          <none>                       (no description available)
un  linux-headers-3.2.0-41-virtual  <none>                       (no description available)
ii  linux-headers-3.2.0-43          3.2.0-43.68                  Header files related to Linux kernel version 3.2.0
ii  linux-headers-3.2.0-43-virtual  3.2.0-43.68                  Linux kernel headers for version 3.2.0 on 64 bit x86 Virtual Guests
ii  linux-headers-3.2.0-44          3.2.0-44.69                  Header files related to Linux kernel version 3.2.0
in  linux-headers-3.2.0-44-virtual  <none>                       (no description available)
ii  linux-headers-3.2.0-45          3.2.0-45.70                  Header files related to Linux kernel version 3.2.0
ii  linux-headers-3.2.0-45-virtual  3.2.0-45.70                  Linux kernel headers for version 3.2.0 on 64 bit x86 Virtual Guests
iU  linux-headers-virtual           3.2.0.44.53                  Linux kernel headers for virtual machines
un  linux-image                     <none>                       (no description available)
un  linux-image-3.0                 <none>                       (no description available)
ii  linux-image-3.2.0-23-virtual    3.2.0-23.36                  Linux kernel image for version 3.2.0 on 64 bit x86 Virtual Guests
ii  linux-image-3.2.0-30-virtual    3.2.0-30.48                  Linux kernel image for version 3.2.0 on 64 bit x86 Virtual Guests
ii  linux-image-3.2.0-31-virtual    3.2.0-31.50                  Linux kernel image for version 3.2.0 on 64 bit x86 Virtual Guests
ii  linux-image-3.2.0-32-virtual    3.2.0-32.51                  Linux kernel image for version 3.2.0 on 64 bit x86 Virtual Guests
ii  linux-image-3.2.0-33-virtual    3.2.0-33.52                  Linux kernel image for version 3.2.0 on 64 bit x86 Virtual Guests
ii  linux-image-3.2.0-34-virtual    3.2.0-34.53                  Linux kernel image for version 3.2.0 on 64 bit x86 Virtual Guests
ii  linux-image-3.2.0-35-virtual    3.2.0-35.55                  Linux kernel image for version 3.2.0 on 64 bit x86 Virtual Guests
ii  linux-image-3.2.0-36-virtual    3.2.0-36.57                  Linux kernel image for version 3.2.0 on 64 bit x86 Virtual Guests
rc  linux-image-3.2.0-37-virtual    3.2.0-37.58                  Linux kernel image for version 3.2.0 on 64 bit x86 Virtual Guests
rc  linux-image-3.2.0-38-virtual    3.2.0-38.61                  Linux kernel image for version 3.2.0 on 64 bit x86 Virtual Guests
rc  linux-image-3.2.0-39-virtual    3.2.0-39.62                  Linux kernel image for version 3.2.0 on 64 bit x86 Virtual Guests
rc  linux-image-3.2.0-40-virtual    3.2.0-40.64                  Linux kernel image for version 3.2.0 on 64 bit x86 Virtual Guests
rc  linux-image-3.2.0-41-virtual    3.2.0-41.66                  Linux kernel image for version 3.2.0 on 64 bit x86 Virtual Guests
ii  linux-image-3.2.0-43-virtual    3.2.0-43.68                  Linux kernel image for version 3.2.0 on 64 bit x86 Virtual Guests
ii  linux-image-3.2.0-44-virtual    3.2.0-44.69                  Linux kernel image for version 3.2.0 on 64 bit x86 Virtual Guests
ii  linux-image-3.2.0-45-virtual    3.2.0-45.70                  Linux kernel image for version 3.2.0 on 64 bit x86 Virtual Guests
ii  linux-image-virtual             3.2.0.45.54                  Linux kernel image for virtual machines
un  linux-initramfs-tool            <none>                       (no description available)
Свободное пространство, по запросу:
df -h
Filesystem              Size  Used Avail Use% Mounted on
/dev/mapper/cacti-root  3.2G  1.6G  1.5G  53% /
udev                    239M  4.0K  239M   1% /dev
tmpfs                    97M  236K   97M   1% /run
none                    5.0M     0  5.0M   0% /run/lock
none                    243M     0  243M   0% /run/shm
/dev/sda1               228M   82M  134M  38% /boot
Одна вещь, которую я должен упомянуть, состоит в том, что на самом деле у меня не было достаточно inodes left ( df -i показывало 100% IUse% для / dev / mapper / cacti-root). Мне пришлось вручную удалять файлы из /usr/src/linux-headers-X.X.X-XX для более старых версий. Теперь, однако, это не проблема.
Прежде всего, спасибо за вашу помощь lgarzo. Я попытался установить linux-headers-3.2.0-44-virtual, как было предложено. Вот результат:
dpkg --install linux-headers-3.2.0-44-virtual
dpkg: error processing linux-headers-3.2.0-44-virtual (--install):
 cannot access archive: No such file or directory
Проверяя / usr / src / для необходимых файлов, кажется, что отсутствуют те из linux-headers-3.2.0-44-virtual:
cd /usr/src/
ls -l
total 20
drwxr-xr-x 24 root root 4096 May 16 06:57 linux-headers-3.2.0-43
drwxr-xr-x  7 root root 4096 May 16 06:57 linux-headers-3.2.0-43-virtual
drwxr-xr-x 24 root root 4096 May 24 06:41 linux-headers-3.2.0-44
drwxr-xr-x 24 root root 4096 Jun  6 14:48 linux-headers-3.2.0-45
drwxr-xr-x  7 root root 4096 Jun  6 14:48 linux-headers-3.2.0-45-virtual
У меня есть как обычный, так и виртуальный для ... 43 и ... 45, но не виртуальный пакет для ... 44. Похоже, что проблема с инодами возникла во время этого автоматического обновления 24 мая, и она была оставлена ​​наполовину.
Есть ли способ загрузить и извлечь эти файлы, чтобы dpkg --install не удалось? Спасибо.
Хорошо, кажется, мы куда-то двигаемся (надеемся в правильном направлении). Я загрузил linux-headers-3.2.0-44-virtual_3.2.0-44.69_i386.deb и попытался сделать dpkg -install . Теперь он жалуется по другим причинам: (
# wget http://launchpadlibrarian.net/140046439/linux-headers-3.2.0-44-virtual_3.2.0-44.69_i386.deb
--2013-06-12 09:49:51--  http://launchpadlibrarian.net/140046439/linux-headers-3.2.0-44-virtual_3.2.0-44.69_i386.deb
Resolving launchpadlibrarian.net (launchpadlibrarian.net)... 91.189.89.228, 91.189.89.229
Connecting to launchpadlibrarian.net (launchpadlibrarian.net)|91.189.89.228|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 979370 (956K) [application/x-debian-package]
Saving to: 'linux-headers-3.2.0-44-virtual_3.2.0-44.69_i386.deb'
100%[==========================================================================================>] 979,370     --.-K/s   in 0.04s
2013-06-12 09:49:51 (22.9 MB/s) - 'linux-headers-3.2.0-44-virtual_3.2.0-44.69_i386.deb' saved [979370/979370]
# dpkg --install linux-headers-3.2.0-44-virtual_3.2.0-44.69_i386.deb
Selecting previously unselected package linux-headers-3.2.0-44-virtual:i386.
(Reading database ... 89164 files and directories currently installed.)
Unpacking linux-headers-3.2.0-44-virtual:i386 (from linux-headers-3.2.0-44-virtual_3.2.0-44.69_i386.deb) ...
dpkg: dependency problems prevent configuration of linux-headers-3.2.0-44-virtual:i386:
 linux-headers-3.2.0-44-virtual:i386 depends on linux-headers-3.2.0-44.
 linux-headers-3.2.0-44-virtual:i386 depends on libc6 (>= 2.11).
dpkg: error processing linux-headers-3.2.0-44-virtual:i386 (--install):
Файлы извлекаются правильно до /usr/src/ , но я полагаю, что еще есть некоторые шаги.
# cd /usr/src
# ls -l
total 24
drwxr-xr-x  7 root root 4096 Jun 12 09:37 linux-headers-3.2.0-44-virtual
Любая идея? (Большое спасибо за ваше терпение и поддержку).
# dpkg --list linux-headers-3.2.0-44 libc6 linux-virtual | cat
ii  libc6                               2.15-0ubuntu10.3             Embedded GNU C Library: Shared libraries
iU  linux-virtual                       3.2.0.44.53                  Complete Linux kernel for virtual machines
Увидев прописную букву U помимо linux-virtual, я также попытался:
# apt-get install linux-virtual
You might want to run 'apt-get -f install' to correct these:
 linux-headers-3.2.0-44-virtual:i386 : Depends: linux-headers-3.2.0-44:i386 but it is not installable
                                       Depends: libc6:i386 (>= 2.11) but it is not going to be installed
 linux-headers-virtual : Depends: linux-headers-3.2.0-44-virtual but it is not going to be installed
 linux-virtual : Depends: linux-headers-virtual (= 3.2.0.45.54) but 3.2.0.44.53 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Это x64 !!!
# dpkg --print-architecture
amd64
Я думаю, что загрузка x64-файлов может помочь;)
Вот шаги, которые я сделал (вместе с их выходами), теперь, когда я понял, что это 64-битная машина.
Загрузите и установите правильный файл .deb
# wget http://launchpadlibrarian.net/140040575/linux-headers-3.2.0-44-virtual_3.2.0-44.69_amd64.deb
--2013-06-14 08:08:49--  http://launchpadlibrarian.net/140040575/linux-headers-3.2.0-44-virtual_3.2.0-44.69_amd64.deb
Resolving launchpadlibrarian.net (launchpadlibrarian.net)... 91.189.89.229, 91.189.89.228
Connecting to launchpadlibrarian.net (launchpadlibrarian.net)|91.189.89.229|:80... connected.
Length: 983134 (960K) [application/x-debian-package]
Saving to: 'linux-headers-3.2.0-44-virtual_3.2.0-44.69_amd64.deb'
100%[==========================================================================================>] 983,134      151K/s   in 20s
2013-06-14 08:09:10 (48.7 KB/s) - 'linux-headers-3.2.0-44-virtual_3.2.0-44.69_amd64.deb' saved [983134/983134]
# dpkg --install linux-headers-3.2.0-44-virtual_3.2.0-44.69_amd64.deb
Unpacking linux-headers-3.2.0-44-virtual (from linux-headers-3.2.0-44-virtual_3.2.0-44.69_amd64.deb) ...
Setting up linux-headers-3.2.0-44-virtual (3.2.0-44.69) ...
Проверьте содержимое каталога / usr / src
# cd /usr/src
# ls -l
total 24
drwxr-xr-x  7 root root 4096 Jun 14 08:12 linux-headers-3.2.0-44-virtual
Попробуйте apt-get update & amp; обновить
# apt-get update
[Ends successfully]
# apt-get upgrade
Он терпит неудачу, жалуется, поэтому я пытаюсь использовать флаг -f (orce)
# apt-get -f upgrade
The following NEW packages will be installed:
  linux-headers-3.2.0-48 linux-headers-3.2.0-48-virtual linux-image-3.2.0-48-virtual
The following packages have been kept back:
  mysql-client-5.5 mysql-server-5.5 mysql-server-core-5.5
  aptitude bash dmsetup isc-dhcp-client isc-dhcp-common libc-bin libc6 libdbus-1-3 libdevmapper-event1.02.1 libdevmapper1.02.1
  libdrm-intel1 libdrm-nouveau1a libdrm-radeon1 libdrm2 libgnutls26 libmysqlclient18 libplymouth2 libssl1.0.0 libudev0 libx11-6
  libx11-data libxcb-render0 libxcb-shm0 libxcb1 libxrender1 linux-headers-virtual linux-image-virtual linux-virtual lvm2
  multiarch-support mysql-client-core-5.5 mysql-common mysql-server openssl plymouth python-apt python-apt-common rsyslog udev
39 upgraded, 3 newly installed, 0 to remove and 3 not upgraded.
Need to get 42.6 MB of archives.
After this operation, 102 MB of additional disk space will be used.
Get:1 http://es.archive.ubuntu.com/ubuntu/ precise-updates/main linux-image-3.2.0-48-virtual amd64 3.2.0-48.74 [12.5 MB]
Get:2 http://es.archive.ubuntu.com/ubuntu/ precise-updates/main linux-virtual amd64 3.2.0.48.58 [1,758 B]
Get:3 http://es.archive.ubuntu.com/ubuntu/ precise-updates/main linux-image-virtual amd64 3.2.0.48.58 [2,390 B]
Get:4 http://es.archive.ubuntu.com/ubuntu/ precise-updates/main linux-headers-3.2.0-48 all 3.2.0-48.74 [11.7 MB]
Get:5 http://es.archive.ubuntu.com/ubuntu/ precise-updates/main libc-bin amd64 2.15-0ubuntu10.4 [1,181 kB]
Get:6 http://es.archive.ubuntu.com/ubuntu/ precise-updates/main libc6 amd64 2.15-0ubuntu10.4 [4,653 kB]
Found linux image: /boot/vmlinuz-3.2.0-43-virtual
Found initrd image: /boot/initrd.img-3.2.0-43-virtual
Found linux image: /boot/vmlinuz-3.2.0-36-virtual
Found initrd image: /boot/initrd.img-3.2.0-36-virtual
Found linux image: /boot/vmlinuz-3.2.0-35-virtual
Found initrd image: /boot/initrd.img-3.2.0-35-virtual
Found linux image: /boot/vmlinuz-3.2.0-34-virtual
Found initrd image: /boot/initrd.img-3.2.0-34-virtual
done
Setting up linux-image-virtual (3.2.0.48.58) ...
Setting up linux-headers-3.2.0-48 (3.2.0-48.74) ...
Setting up linux-headers-3.2.0-48-virtual (3.2.0-48.74) ...
Setting up linux-headers-virtual (3.2.0.44.53) ...
  Version of linux-image-virtual on system is 3.2.0.48.58.
Setting up libdbus-1-3 (1.4.18-1ubuntu1.4) ...
Setting up libdrm2 (2.4.43-0ubuntu0.0.1) ...
Setting up libdrm-intel1 (2.4.43-0ubuntu0.0.1) ...
Setting up libdrm-nouveau1a (2.4.43-0ubuntu0.0.1) ...
update-initramfs: deferring update (trigger activated)
Processing triggers for libc-bin ...
ldconfig deferred processing now taking place
Processing triggers for initramfs-tools ...
update-initramfs: Generating /boot/initrd.img-3.2.0-48-virtual
 linux-virtual
Он снова не работает, также жалуется на linux-virtual. Единственное отличие состоит в том, что, поскольку я запускаю с установленным флагом -f (orce), теперь у меня уже установлен 3.2.0.48.58 .
Ранее жалоба была:
linux-virtual зависит от linux-image-virtual (= 3.2.0.44.53), но 3.2.0.45.54 установлен
Теперь это:
linux-virtual зависит от linux-image-virtual (= 3.2.0.44.53), но установлен 3.2.0.48.58
#  dpkg --configure linux-virtual
 linux-virtual
# ls -l /usr/src
total 32
drwxr-xr-x 24 root root 4096 Jun 14 08:16 linux-headers-3.2.0-48
drwxr-xr-x  7 root root 4096 Jun 14 08:16 linux-headers-3.2.0-48-virtual
ii  libc6                               2.15-0ubuntu10.4             Embedded GNU C Library: Shared libraries
# uname -r
3.2.0-45-virtual
Любые идеи?
Если вы все еще считаете, что самый простой способ следить за ним - это вернуться к предыдущей версии ядра и позволить ему обновляться оттуда, я думаю, что мы можем использовать 3.2.0.43 , так как у меня есть linux-headers-3.2.0-43 и linux-headers-3.2.0-43-virtual в /usr/src/ , а также все необходимые файлы в /boot/
# ls -l /boot/*3.2.0-43*
-rw-r--r-- 1 root root  794949 May 15 06:33 /boot/abi-3.2.0-43-virtual
-rw-r--r-- 1 root root  140637 May 15 06:33 /boot/config-3.2.0-43-virtual
-rw-r--r-- 1 root root 4791807 May 16 06:57 /boot/initrd.img-3.2.0-43-virtual
-rw------- 1 root root 2890123 May 15 06:33 /boot/System.map-3.2.0-43-virtual
-rw------- 1 root root 4961104 May 15 06:33 /boot/vmlinuz-3.2.0-43-virtual
Спасибо.
Это также мешает мне установить его:
# wget http://launchpadlibrarian.net/141816244/linux-virtual_3.2.0.48.58_amd64.deb
--2013-06-14 11:42:37--  http://launchpadlibrarian.net/141816244/linux-virtual_3.2.0.48.58_amd64.deb
Length: 1758 (1.7K) [application/x-debian-package]
Saving to: 'linux-virtual_3.2.0.48.58_amd64.deb'
100%[==========================================================================================>] 1,758       --.-K/s   in 0s
2013-06-14 11:42:37 (184 MB/s) - 'linux-virtual_3.2.0.48.58_amd64.deb' saved [1758/1758]
# dpkg --install linux-virtual_3.2.0.48.58_amd64.deb
(Reading database ... 120232 files and directories currently installed.)
Preparing to replace linux-virtual 3.2.0.44.53 (using linux-virtual_3.2.0.48.58_amd64.deb) ...
Unpacking replacement linux-virtual ...
 linux-virtual depends on linux-headers-virtual (= 3.2.0.48.58); however:
  Version of linux-headers-virtual on system is 3.2.0.44.53.
dpkg: error processing linux-virtual (--install):
 linux-virtual
Загрузите два файла .deb
# wget http://launchpadlibrarian.net/141821073/linux-headers-3.2.0-48-virtual_3.2.0-48.74_amd64.deb
# wget http://launchpadlibrarian.net/141823437/linux-headers-3.2.0-48_3.2.0-48.74_all.deb
Установить их
# dpkg --install linux-headers-3.2.0-48-virtual_3.2.0-48.74_amd64.deb
Preparing to replace linux-headers-3.2.0-48-virtual 3.2.0-48.74 (using linux-headers-3.2.0-48-virtual_3.2.0-48.74_amd64.deb) ...
Unpacking replacement linux-headers-3.2.0-48-virtual ...
# dpkg --install linux-headers-3.2.0-48_3.2.0-48.74_all.deb
Preparing to replace linux-headers-3.2.0-48 3.2.0-48.74 (using linux-headers-3.2.0-48_3.2.0-48.74_all.deb) ...
Unpacking replacement linux-headers-3.2.0-48 ...
Попробуйте установить исходный пакет .deb, которые не удовлетворяли
Preparing to replace linux-virtual 3.2.0.48.58 (using linux-virtual_3.2.0.48.58_amd64.deb) ...
 linux-virtual
Поскольку он все еще жалуется, я думаю, я должен загрузить и установить недостающий пакет. Этот шаг сам по себе:)
# wget http://launchpadlibrarian.net/141816242/linux-headers-virtual_3.2.0.48.58_amd64.deb
# dpkg --install linux-headers-virtual_3.2.0.48.58_amd64.deb
Preparing to replace linux-headers-virtual 3.2.0.44.53 (using linux-headers-virtual_3.2.0.48.58_amd64.deb) ...
Unpacking replacement linux-headers-virtual ...
Setting up linux-headers-virtual (3.2.0.48.58) ...
Попробуйте установить пакет с ошибками
Setting up linux-virtual (3.2.0.48.58) ...
И, наконец, работал !!!!!
# apt-get update
# apt-get upgrade
Все в порядке и без ошибок. СПАСИБО МНОГО lgarzo !!!
Пожалуйста, опубликуйте что-то в качестве ответа (вместо комментария), чтобы я мог дать вам кредит за вашу неоценимую помощь.
Приветствия.
задан jagb 14.06.2013 в 12:14
Предисловие: это была небольшая сессия вопросов. Этот ответ суммирует шаги, ведущие к решению (исключая некоторые тупики).
Сначала нам нужна была информация о системе. (Его можно получить, открыв окно терминала и запустив заданные команды в приглашении.):
  • Используемое в настоящее время ядро: uname -r
  • В настоящее время установленные пакеты ядра и заголовков: dpkg --list linux-[hi]* | cat
  • Текущая архитектура: dpkg --print-architecture
  • Свободное место на диске в системе: df -h
  • Бесплатные inodes в системе: df -i
Корень проблемы неудовлетворенных зависимостей заключался в отсутствии свободного пространства / inodes за какое-то время. При установке ядер / заголовков всегда рекомендуется иметь не менее 150 МБ свободного места в /lib (или /root , если вы использовали метод автоматического разбиения при установке). Кроме того, количество свободных инодов не должно быть около 100%, потому что на этих пакетах установлено много файлов.
Убедившись, что у вас достаточно свободного места для хранения этих файлов, мы продолжили установку отсутствующих пакетов, загрузив их и используя dpkg --install package.deb . (Обратите внимание, что при установке пакетов вручную вы несете ответственность за выполнение зависимостей пакета. В этом случае мы не могли использовать apt , просто потому, что система находилась в несогласованном состоянии, и она не работала.)
Нам нужно было определить, какие пакеты отсутствуют. Это было намечено в сообщениях об ошибках зависимости от команды dpkg ( apt ).
Чтобы выполнить первую зависимость:
Необходим следующий пакет:
  • linux-headers-3.2.0-44-virtual_3.2.0-44.69_amd64.deb
Чтобы выполнить вторую (и далее) зависимость:
Необходимы следующие пакеты:
  • linux-virtual_3.2.0.48.58_amd64.deb
  • linux-headers-3.2.0-48-virtual_3.2.0-48.74_amd64.deb
  • linux-headers-3.2.0-48_3.2.0-48.74_all.deb
  • linux-headers-virtual_3.2.0.48.58_amd64.deb
Локализация пакетов была небольшим количеством квеста. Но вы можете получить их, используя следующий метод:
  • Откройте страницу Linux Lunchpad .
  • Нажмите «Все пакеты»,
  • выберите «Precise» Distribution series и «linux» или «linux-meta» исходный пакет, затем
  • выберите версию, которую вы ищете.
  • Нажмите на соответствующий двоичный пакет и
  • выберите свой пакет из списка.
  • Взгляните на загружаемые файлы.
Чтобы установить загруженный пакет:
  • Сохраните его в каталоге,
  • cd внутри и
  • use dpkg --install downloaded_package_name.deb для установки пакета.
Убедитесь, что вы покинули каталог перед запуском dpkg --list запросов.
После выполнения всех зависимостей вы можете запустить
apt-get update && apt-get upgrade
И не должно появляться сообщений об ошибках. Могут быть новые / обновленные пакеты, поскольку система не смогла обновить себя через некоторое время.
ответ дан lgarzo 14.06.2013 в 13:03
Многое, гораздо более простое решение, которое не требует ручной загрузки пакетов и обхода подписания пакета и т. д .:
sudo apt-get remove linux-headers-virtual linux-virtual
sudo apt-get install linux-headers-virtual linux-virtual
sudo apt-get -f install
sudo apt-get autoremove
Последние два этапа являются необязательными и просто проверяют установку и очистку соответственно.
ответ дан andyzei 18.01.2015 в 09:00
Попробуйте это. Просто нажмите Ctrl + Alt + T на клавиатуре, чтобы открыть терминал. Когда он откроется, запустите следующие команды:
sudo apt-get clean
sudo apt-get update && sudo apt-get upgrade
ответ дан Mitch 06.06.2013 в 14:19
Просто хочу сказать, что я столкнулся с той же проблемой. Никто не упомянул об этом, но разве это не ошибка? Я имею в виду, если мы сможем принудительно установить некоторые пакеты и исправить их вручную, не должны ли вы сами это понять и выполнить необходимую работу?
У меня есть небольшой / загрузочный раздел, и через некоторое время слишком много установленных ядер сделали раздел полным. Я начал получать подобное сообщение об ошибке, я не буду воспроизводить информацию здесь, потому что они точно такие же, как уже сообщалось.
Цель этого сообщения - просто поднять флаг по этой проблеме, он воздействует на других людей и уходит в состояние, когда обновления безопасности не применяются, когда они должны. На сервере, обращенном к Интернету, это может стать кошмаром, если критическая уязвимость безопасности не исправлена ​​достаточно быстро, потому что apt сломан.
ответ дан mbello 03.07.2013 в 22:12
