Когда я хочу установить любой пакет, я получаю это:
[email protected]:~# apt-get install nginx
Reading package lists... Done
Building dependency tree
nginx is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
203 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue [Y/n]? y
Setting up gconf2 (2.28.1-6) ...
dpkg: error processing gconf2 (--configure):
subprocess installed post-installation script returned error exit status 247
dpkg: dependency problems prevent configuration of libgweather-common:
libgweather-common depends on gconf2 (>= 2.28.1-2); however:
Package gconf2 is not configured yet.
dpkg: error processing libgweather-common (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of libgweather1:
libgweather1 depends on libgweather-common (>= 2.24.0); however:
Package libgweather-common is not configured yet.
dpkg: error processing libgweather1 (--configure):
dpkg: dependency problems prevent configuration of evolution-data-server:
evolution-data-server depends on libgweather1 (>= 2.30.0); however:
Package libgweather1 is not configured yet.
dpkg: error processing evolution-data-server (--configure):
dpkg: dependency problems prevent conficonfigured to not write apport reports
guration of evolution:
evolution depends on libgweather1 (>= 2.30.0); however:
evolution depends on gconf2 (>= 2.28.1-2); however:
evolution depends on evolution-data-server (>= 2.30.3); however:
Package evolution-data-server is not configured yet.
evolution depends on evolution-data-server (<< 2.31); however:
dpkg: error processing evolution (--configure):
dpkg: dependency problems prevent configuration of at-spi:
at-spi depends on gconf2 (>= 2.28.1-2); however:
dpkg: error processing at-spi (--configure):
dpkg: dependency problems prevent configuration of baobab:
baobab depends on gconf2 (>= 2.28.1-2); however:
dpkg: error processing baobab (--configure):
dependency problems configured to not write apport reports
dpkg: dependency problems prevent configuration of brasero-common:
brasero-common depends on gconf2 (>= 2.28.1-2); however:
dpkg: error processing brasero-common (--configure):
dpkg: dependency problems prevent configuration of libbrasero-media0:
libbrasero-media0 depends on brasero-common (>= 2.30); however:
Package brasero-common is not configured yet.
libbrasero-media0 depends on brasero-common (<< 2.31); however:
dpkg: error processing libbrasero-media0 (--configure):
dpkg: dependency problems prevent configuration of brasero:
brasero depends on libbrasero-media0 (= 2.30.3-2); however:
Package libbrasero-media0 is not configured yet.
brasero depends on brasero-common (>= 2.30); however:
brasero depends on brasero-common (<< 2.31); however:
dpkg: error processing brasero (--configure):
dpkg: dependency problems prevent configuration of capplets-data:
capplets-data depends on gconf2 (>= 2.28.1-2); however:
dpkg: error processing capplets-data (--configure):
dpkg: dependency problems prevent configuration of cheese-common:
cheese-common depends on gconf2 (>= 2.28.1-2); however:
dpkg: error processing cheese-common (--configure):
dpkg: dependency problems prevent configuration of gstreamer0.10-plugins-good:
gstreamer0.10-plugins-good depends on gconf2 (>= 2.28.1-2); however:
dpkg: error processing gstreamer0.10-plugins-good (--configure):
dpkg: dependency problems prevent configuration of cheese:
cheese depends on cheese-common (= 2.30.1-2); however:
Package cheese-common is not configured yet.
cheese depends on gstreamer0.10-plugins-good (>= 0.10.23); however:
Package gstreamer0.10-plugins-good is not configured yet.
dpkg: error processing cheese (--configure):
dpkg: dependency problems prevent configuration of libgnomevfs2-common:
libgnomevfs2-common depends on gconf2 (>= 2.12.1-1); however:
dpkg: error processing libgnomevfs2-common (--configure):
dpkg: dependency problems prevent configuration of libgnomevfs2-0:
libgnomevfs2-0 depends on libgnomevfs2-common (>= 1:2.24); however:
Package libgnomevfs2-common is not configured yet.
libgnomevfs2-0 depends on libgnomevfs2-common (<< 1:2.25); however:
dpkg: error processing libgnomevfs2-0 (--configure):
dpkg: dependency problems prevent configuration of libgnome2-common:
libgnome2-common depends on gconf2 (>= 2.12.1-1); however:
dpkg: error processing libgnome2-common (--configure):
dpkg: dependency problems prevent configuration of libgnome2-0:
libgnome2-0 depends on libgnomevfs2-0 (>= 1:2.17.90); however:
Package libgnomevfs2-0 is not configured yet.
libgnome2-0 depends on libgnome2-common (>= 2.30); however:
Package libgnome2-common is not configured yet.
libgnome2-0 depends on libgnome2-common (<< 2.31); however:
dpkg: error processing libgnome2-0 (--configure):
dpkg: dependency problems prevent configuration of libbonoboui2-0:
libbonoboui2-0 depends on libgnome2-0 (>= 2.17.3); however:
Package libgnome2-0 is not configured yet.
dpkg: error processing libbonoboui2-0 (--configure):
dpkg: dependency problems prevent configuration of libgnomeui-0:
libgnomeui-0 depends on libbonoboui2-0 (>= 2.15.1); however:
Package libbonoboui2-0 is not configured yet.
libgnomeui-0 depends on libgnome2-0 (>= 2.17.3); however:
libgnomeui-0 depends on libgnomevfs2-0 (>= 1:2.17.90); however:
dpkg: error processing libgnomeui-0 (--configure):
dpkg: dependency problems prevent configuration of dasher-data:
dasher-data depends on gconf2 (>= 2.10.1-2); however:
dpkg: error processing dasher-data (--configure):
dpkg: dependency problems prevent configuration of dasher:
dasher depends on libbonoboui2-0 (>= 2.15.1); however:
dasher depends on libgnome2-0 (>= 2.17.3); however:
dasher depends on libgnomeui-0 (>= 2.22.0); however:
Package libgnomeui-0 is not configured yet.
dasher depends on libgnomevfs2-0 (>= 1:2.17.90); however:
dasher depends on at-spi; however:
Package at-spi is not configured yet.
dasher depends on dasher-data (>= 4.11-1); however:
Package dasher-data is not configured yet.
dasher depends on dasher-data (<< 4.12); however:
dpkg: error processing dasher (--configure):
dpkg: dependency problems prevent configuration of libpanel-applet2-0:
libpanel-applet2-0 depends on libbonoboui2-0 (>= 2.15.1); however:
Package libbonoboui2-0 is not configuconfigured to not write apport reports
red yet.
dpkg: error processing libpanel-applet2-0 (--configure):
dpkg: dependency problems prevent configuration of python-gnome2:
python-gnome2 depends on libbonoboui2-0 (>= 2.15.1); however:
python-gnome2 depends on libgnome2-0 (>= 2.17.3); however:
python-gnome2 depends on libgnomeui-0 (>= 2.22.0); however:
python-gnome2 depends on libgnomevfs2-0 (>= 1:2.17.90); however:
dpkg: error processing python-gnome2 (--configure):
dpkg: dependency problems prevent configuration of python-gnomeapplet:
python-gnomeapplet depends on libbonoboui2-0 (>= 2.15.1); however:
python-gnomeapplet depends on libgnome2-0 (>= 2.17.3); however:
configured to not write apport reportsd yet.
python-gnomeapplet depends on libgnomeui-0 (>= 2.22.0); however:
python-gnomeapplet depends on libgnomevfs2-0 (>= 1:2.17.90); however:
python-gnomeapplet depends on libpanel-applet2-0 (>= 2.28.0); however:
Package libpanel-applet2-0 is not configured yet.
python-gnomeapplet depends on python-gnome2; however:
Package python-gnome2 is not configured yet.
dpkg: error processing python-gnomeapplet (--configure):
dpkg: dependency problems prevent configuration of deskbar-applet:
deskbar-applet depends on gconf2 (>= 2.28.1-2); however:
deskbar-applet depends on python-gnomeapplet; however:
Package python-gnomeapplet is not configured yet.
dpkg: error processing deskbar-applet (--configure):
dpkg: dependency problems prevent configuration of ekiga:
ekiga depends on gconf2 (>= 2.28.1-2); however:
ekiga depends on evolution-data-server; however:
dpkg: error processing ekiga (--configure):
dpkg: dependency problems prevent configuration of libgstfarsight0.10-0:
libgstfarsight0.10-0 depends on gstreamer0.10-plugins-good (>= 0.10.8); however:
dpkg: error processing libgstfarsight0.10-0 (--configure):
dpkg: dependency problems prevent configuration of libtelepathy-farsight0:
libtelepathy-farsight0 depends on libgstfarsight0.10-0 (>= 0.0.3); however:
Package libgstfarsight0.10-0 is not configured yet.
dpkg: error processing libtelepathy-farsight0 (--configure):
dpkg: dependency problems prevent configuration of empathy:
empathy depends on libgstfarsight0.10-0 (>= 0.0.1); however:
empathy depends on libtelepathy-farsight0 (>= 0.0.6); however:
Package libtelepathy-farsight0 is not configured yet.
empathy depends on gconf2 (>= 2.28.1-2); however:
dpkg: error processing empathy (--configure):
dpkg: dependency problems prevent configuration of eog:
eog depends on gconf2 (>= 2.28.1-2); however:
dpkg: error processing eog (--configure):
dpkg: dependency problems prevent configuration of epiphany-browser-data:
epiphany-browser-data depends on gconf2 (>= 2.28.1-2); however:
dpkg: error processing epiphany-browser-data (--configure):
dpkg: dependency problems prevent configuration of epiphany-browser:
epiphany-browser depends on epiphany-browser-data (>= 2.30); however:
Package epiphany-browser-data is not configured yet.
epiphany-browser depends on epiphany-browser-data (<< 2.31); however:
dpkg: error processing epiphany-browser (--configure):
dpkg: dependency problems prevent configuration of epiphany-extensions:
epiphany-extensions depends on epiphany-browser (>= 2.30.2); however:
Package epiphany-browser is not configured yet.
epiphany-extensions depends on epiphany-browser (<< 2.31); however:
dpkg: error processing epiphany-extensions (--configure):
dpkg: dependency problems prevent configuration of evince:
evince depends on gconf2 (>= 2.28.1-2); however:
dpkg: error processing evince (--configure):
dpkg: dependency problems prevent configuration of evolution-exchange:
evolution-exchange depends on gconf2 (>= 2.28.1-2); however:
evolution-exchange depends on evolution (>= 2.30.0); however:
Package evolution is not configured yet.
evolution-exchange depends on evolution (<< 2.31.0); however:
dpkg: error processing evolution-exchange (--configure):
dpkg: dependency problems prevent configuration of evolution-webcal:
evolution-webcal depends on gconf2 (>= 2.28.1-2); however:
dpkg: error processing evolution-webcal (--configure):
dpkg: dependency problems prevent configuration of file-roller:
file-roller depends on gconf2 (>= 2.28.1-2); however:
dpkg: error processing file-roller (--configure):
dpkg: dependency problems prevent configuration of gcalctool:
gcalctool depends on gconf2 (>= 2.28.1-2); however:
dpkg: error processing gcalctool (--configure):
dpkg: dependency problems prevent configuration of gconf-editor:
gconf-editor depends on gconf2 (>= 2.10.1-2); however:
dpkg: error processing gconf-editor (--configure):
dpkg: dependency problems prevent configuration of libgksu2-0:
libgksu2-0 depends on gconf2 (>= 2.28.1-2); however:
dpkg: error processing libgksu2-0 (--configure):
dpkg: dependency problems prevent configuration of gksu:
gksu depends on libgksu2-0 (>= 2.0.8); however:
Package libgksu2-0 is not configured yet.
dpkg: error processing gksu (--configure):
dpkg: dependency problems prevent configuration of gdebi:
gdebi depends on gksu (>= 2.0.0-1ubuntu3); however:
Package gksu is not configured yet.
dpkg: error processing gdebi (--configure):
dpkg: dependency problconfigured to not write apport reports
ems prevent configuration of gedit:
gedit depends on gconf2 (>= 2.28.1-2); however:
dpkg: error processing gedit (--configure):
dpkg: dependency problems prevent configuration of gnome-about:
gnome-about depends on python-gnome2; however:
dpkg: error processing gnome-about (--configure):
dpkg: dependency problems prevent configuration of gnome-applets-data:
gnome-applets-data depends on gconf2 (>= 2.28.1-2); however:
dpkg: error processing gnome-applets-data (--configure):
dpkg: dependency problems prevent configuration of gnome-panel-data:
gnome-panel-data depends on gconf2 (>= 2.28.1-2); however:
dpkg: error processing gnome-panel-data (--configure):
dpkg: dependency problems prevent configuration of gnome-panel:
gnome-panel depends on libbonoboui2-0 (>= 2.15.1); however:
gnome-panel depends on libgweather1 (>= 2.30.0); however:
gnome-panel depends on libpanel-applet2-0 (>= 2.28.0); however:
gnome-panel depends on gnome-panel-data (>= 2.30); however:
Package gnome-panel-data is not configured yet.
gnome-panel depends on gnome-panel-data (<< 2.31); however:
gnome-panel depends on gnome-about (>= 2.10.0-1); however:
Package gnome-about is not configured yet.
gnome-panel depends on python-gnome2; however:
dpkg: error processing gnome-panel (--configure):
dpkg: dependency problems prevent configuration of gnome-applets:
gnome-applets depends on libbonoboui2-0 (>= 2.15.1); however:
gnome-applets depends on libgnome2-0 (>= 2.17.3); however:
gnome-applets depends on libgweather1 (>= 2.30.0); however:
gnome-applets depends on libpanel-applet2-0 (>= 2.28.0); however:
gnome-applets depends on gconf2 (>= 2.28.1-2); however:
gnome-applets depends on gnome-applets-data (>= 2.30); however:
Package gnome-applets-data is not configured yet.
gnome-applets depends on gnome-applets-data (<< 2.31); however:
gnome-applets depends on gnome-panel (>= 2.13.4); however:
Package gnome-panel is not configured yet.
dpkg: error processing gnome-applets (--configure):
dpkg: dependency problems prevent configuration of libgnomekbd-common:
libgnomekbd-common depends on gconf2 (>= 2.28.1-2); however:
dpkg: error processing libgnomekbd-common (--configure):
dpkg: dependency problems prevent configuration of libgnomekbd4:
libgnomekbd4 depends on libgnomekbd-common (>= 2.30.2-2); however:
Package libgnomekbd-common is not configured yet.
dpkg: error processing libgnomekbd4 (--configure):
dpkg: too many errors, stopping
gconf2
libgweather-common
libgweather1
evolution
at-spi
baobab
brasero-common
libbrasero-media0
brasero
capplets-data
cheese-common
cheese
libgnomevfs2-common
libgnomevfs2-0
libgnome2-common
libgnome2-0
libbonoboui2-0
libgnomeui-0
dasher-data
dasher
libpanel-applet2-0
python-gnome2
python-gnomeapplet
deskbar-applet
ekiga
empathy
eog
epiphany-browser
epiphany-extensions
evince
evolution-exchange
evolution-webcal
file-roller
gcalctool
gconf-editor
libgksu2-0
gksu
gdebi
gedit
gnome-about
gnome-applets-data
gnome-panel-data
gnome-panel
gnome-applets
libgnomekbd-common
libgnomekbd4
Processing was halted because there were too many errors.
