Что такое «dist-upgrade» и почему он обновляется больше, чем «обновление»?
319
Мне было интересно, почему upgrade иногда не хочет обновлять некоторые части системы, а dist-upgrade . Вот пример после запуска apt-get upgrade :
apt-get upgrade :
rimmer@rimmer-Lenovo-IdeaPad-S10-2:~$ sudo apt-get upgrade
Reading package lists... Done
Building dependency tree
The following packages have been kept back:
  linux-generic linux-headers-generic linux-image-generic
0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
против apt-get dist-upgrade :
rimmer@rimmer-Lenovo-IdeaPad-S10-2:~$ sudo apt-get dist-upgrade
Calculating upgrade... Done
The following NEW packages will be installed:
  linux-headers-3.0.0-13 linux-headers-3.0.0-13-generic
  linux-image-3.0.0-13-generic
The following packages will be upgraded:
3 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
Need to get 48.5 MB of archives.
After this operation, 215 MB of additional disk space will be used.
Do you want to continue [Y/n]?
Другими словами, почему это невозможно выполнить upgrade ?
задан Richard Rodriguez 22.11.2011 в 07:03
268
Из apt-get руководства :
upgrade
   upgrade is used to install the newest versions of all packages
   currently installed on the system from the sources enumerated in
   /etc/apt/sources.list. Packages currently installed with new
   versions available are retrieved and upgraded; under no
   circumstances are currently installed packages removed, or packages
   not already installed retrieved and installed. New versions of
   currently installed packages that cannot be upgraded without
   changing the install status of another package will be left at
   their current version. An update must be performed first so that
   apt-get knows that new versions of packages are available.
dist-upgrade
   dist-upgrade in addition to performing the function of upgrade,
   also intelligently handles changing dependencies with new versions
   of packages; apt-get has a "smart" conflict resolution system, and
   it will attempt to upgrade the most important packages at the
   expense of less important ones if necessary. So, dist-upgrade
   command may remove some packages. The /etc/apt/sources.list file
   contains a list of locations from which to retrieve desired package
   files. See also apt_preferences(5) for a mechanism for overriding
   the general settings for individual packages.
И с новым apt инструментом, доступным с 14.04 и далее:
full-upgrade
   full-upgrade performs the function of upgrade but may also remove
   installed packages if that is required in order to resolve a
   package conflict.
В вашем конкретном случае я вижу, например, что linux-headers - это виртуальный пакет, который предоставляется как linux-headers-3.0.0-12 , так и linux-headers-3.0.0-13 , и это звучит как тип установки и удаления пакета, обработанный dist-upgrade , но не upgrade .
ответ дан jcollado 22.11.2011 в 07:57
111
apt-get upgrade ограничивается случаем, когда пакеты должны быть заменены более новыми версиями, но пакет не нужно добавлять или удалять. Например, новая версия Firefox должна быть установлена ​​с помощью apt-get upgrade .
Однако apt-get upgrade откажется работать, если в обновленные версии добавлены или удалены. Например, когда у вас установлен ядро linux-image-3.2.0-10-generic и linux-image-3.2.0-11-generic , пакет linux-image-generic обновляется, чтобы зависеть от более новой версии. Чтобы установить новое ядро, вам нужно запустить apt-get dist-upgrade .
Обратите внимание, что apt-get upgrade скажет, что пакеты ядра были held back . Это подсказка для использования apt-get dist-upgrade .
ответ дан pablomme 27.01.2012 в 17:34
30
В основном обновление будет только обновлять существующие пакеты из одной версии в другую. Он не будет устанавливать или удалять пакеты, даже если это необходимо для обновления других. В случае обновлений ядра для обновления пакета linux-generic требуется установить новый пакет linux-3.0.0-13, а так как обновление отказывается устанавливать или удалять пакеты, оно отказывается обновлять linux-generic.
Иногда различные несовместимости между пакетами требуют, чтобы некоторые пакеты были удалены, чтобы обновить другие, и для этого также потребуется dist-upgrade. Обновления ядра всегда требуют dist-upgrade из-за того, как они обрабатываются. Вместо того, чтобы обновлять пакет ядра, каждый раз создается полностью новый пакет ядра, а метапакет ядра обновляется, чтобы зависеть от нового пакета ядра вместо старого. Это было сделано для сохранения старых версий ядра, чтобы в случае возникновения проблемы с загрузкой нового ядра вы можете выбрать старый из меню загрузки и восстановить.
ответ дан psusi 22.11.2011 в 15:45
Команда apt-get upgrade обычно устанавливает только обновления (или исправления) для установленных пакетов. Как правило, новая версия Mozilla Firefox , например, будет установлена ​​с этой командой.
Однако apt-get upgrade будет НЕ , как правило, устанавливать новые выпуски, где требуются значительные изменения (включая удаление пакетов или обновление GRUB). Например, когда доступно новое ядро ​​Linux (linux-image-3.x.x-xx-generic и т. Д.), Пакет не будет установлен.
Чтобы установить новое ядро, вам нужно запустить apt-get dist-upgrade . Вы будете уведомлены, когда вы запустите apt-get upgrade , так как он скажет, что некоторые пакеты были сдержаны. Это ваша подсказка: apt-get dist-upgrade .
ответ дан david6 28.01.2012 в 01:55
